Hello I have a Beogram 5500 system. When the turntable is working it makes a noise. This can be heard above the sound of the record. I have looked under the platter and the noise can be sources to the small wheel which the belt is attached to. This makes a noise as the turntable is rotated. I would be grateful if anyone could suggest how this might be corrected. Many thanks in advance.
Mike Wilson
