Hi there – just taking apart a BM 1200 amongst many other items in order to have the cabinets re-sprayed in a white lacquer.(RAL 9016 70% matt of course!)
While doing this, I noticed how simple it was to remove the indicator bulbs for MW/LW/FM which I would like to replace. These seem to be labelled PH12/30. Does anyone know a supplier for these or a suitable replacement please?
Many thanks – Alan
I have them in good quality.
Wow Martin - that was astonishingly fast!
I need 12 of those bulbs plus some others for units I have not yet taken apart. I wonder whether you might help with bulbs for these: -
Thanks very much
Alan
Yes.You have email.
Hi, I have a Beomaster 1000, Model 2316. Everything seems to work fine, except the lamps seem to be burned out. I found your post on the forum and wondered if you still have the replacement lamps and do the existing sockets require any modification?. Thanks, Cullen
Yes, I have the correct lamps.
No modifications needed.
PM or e-mail me.
