BEOCORD 5000 Type 4922
This post has 3 Replies | 2 Followers
johnmac119
Posts 1
johnmac119 Posted: Sat, Jan 20 2018 12:07 PM
This cassette deck was purchased by my father in 1985 in the UK along with a Beomaster 5000, Beogram CD 50 Beogram 5000 and a Master Control 5000.
Sometime before he died in 2006 the cassette deck stopped working.  This week I connected all the equipment together and to my surprise the CD and record drive worked but not the cassette player.  In opening it up the first obvious problem is the belts used in my type 4922 tape drive assembly are no where to be seen except for some black mush on one of the spindles.  I have sourced some belts off of ebay.  Can anyone provide a diagram showing how to install the three belts.  Any help appreciated.
FYI I have trawled through the forum and archive and can see this is a common problem often responded to by Martin but I cannot see a response dealing with the type 4922.
Kind regards
John Mace (user name johnmac119)
em: johnmac0574@gmail.com
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Jan 20 2018 3:04 PM
All Beocord 5000 type 49xx are identical when it comes to the drive mech.
The differences are mainly related to the mains voltage, the power plug type and perhaps a few other territory specific things.
First thing would be to ask the seller for instructions.
If the seller cannot help you, he most likely never tried fitting them himself and wouldn't know how or if they work or not.
But, to be honest, if you bought off Ebay you will most likely sit with some belts that look somewhat right but won't fit.
Or they are too large or - even worse - too tight.
It's quite sad, but that's the story told by the amount of Beocords coming in here with wrong belts.
The bronze bearings in the motor won't take too high sideways loads for very long and spare motors are not too plentyful.
I cannot provide instructions for parts I didn't sell. And that's a principle. If something goes wrong with the belts I could be blamed
for it - been there - but I can supply correct belts (own custom production to original specs - no asian standard belts!) and
I can include instructions with photos and english text.
A set with the rubber parts for the idler wheel and the reel tables is also available - though I haven't made any instructions for them since
they are in plain view when servicing the Beocord.
Priory99
Posts 1
Silver Member
Priory99 replied on Sat, Jul 11 2020 8:53 AM
Hi Dillen,
I have started my Covid lockdown project of renovating my Beo 5000 system.  Most of my system seems to still be in working order but the belts (at least those I can  see in the Beocord 5000 Type 4922 are a black mush. After reading all the historic posts ( a big thank you to all those who made contributions) it seems like you are the expert to contact. Do you still supply the belts please?
I'm located in Oxford,UK what's the best way to get them.
Thanks, Robert.
Dillen
Posts 13,191
Dillen replied on Sat, Jul 11 2020 1:37 PM
Robert, you have email.
Page 1 of 1 (4 items) | RSS
