Hi,I've been using my Beosound1 since I bought it using a wireless connection and it works just fine. Since I don't move physically the speaker, I tried to configure the connection using an ethernet cable instead of wireless but I don't how to do it. As soon as I connect the cable, beosound no longer is seen on the app I even if I try to configure as a new product, it is not posible because it is needed a wireless connection. Can you tell me how can I do the configuration?
Thanks!
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Yes
Did you try to reset your BS1 using the button on the device?
That's it! It worked just fine!
You’re welcome ;-)
