AUX volume level, difference on 3000 vs 4500
This post has 0 Replies | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Mon, Jan 29 2018 8:00 AM
Hi All
I have a Beomaster 4500 connected via optical->converter->aux from my TV. It works fine, but the volume is much lower on AUX than cd/radio sources.
I then tested with a Beosound 3000, that seemed to have the same level on all 3 sources.
Is there something that can be changed in the BM4500 that elevates the AUX sensitivity and produces a higher volume ?
Normally it is not a problem, but after having watched tv, and then pressing radio, gives all people kind of a chok because of the higher volume :)
Any ideas ?
/Jacob
Page 1 of 1 (1 items) | RSS
