Hi all,
there are Beovision 11, Moment, Essence and Masterlink Gateway linked in home network by LAN (switch).
It is possible to execute macros by signals from KNX shown by MLGW-monitor, but no effect to TV or Moment...
Normally i use the BeoremoteOne (registered to Beovision),
many thanks for your help
mackaroni
first of all, i would like to wake up BV11-46...
UPDATE: found a problem: in Customer Settings Menu/ in option Reroute light control there are links to Moment/Essence/M5
but NO MLGW was mentioned, a few minutes later MLGW was seen but only for a while!?
Sometimes the web panel/setup menu seems to be offline...??
