beocord 4500 7 pin to 1900/2400 Reciever with 5 pin
This post has 9 Replies | 1 Follower
chief831
Posts 6
Silver Member
chief831 Posted: Sun, Feb 4 2018 8:32 PM
How can I use the Beocord with 7 pin output to play and record om a Beomaster 1900/2400 with only 5 pin input??????/    Thanks so much
Chief
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Feb 4 2018 8:50 PM
The two outermost pins in the Beocords DIN plug can be unscrewed using a very small (watchmakers type) flat bladed screwdriver..
Store the pins a safe place, f.e. taped to the underside or backside of the Beocord.
chief831
Posts 6
Silver Member
chief831 replied on Sun, Feb 4 2018 10:21 PM
Thanks Martin....will the beocord 4500 record tapes after removing the extra two pins....again....thanks
Chief
Dillen
Posts 13,191
Dillen replied on Sun, Feb 4 2018 10:26 PM
Yes.
The two pins are for datalink (remote control), - not supported by your Beomaster anyways.
chief831
Posts 6
Silver Member
chief831 replied on Sun, Feb 4 2018 11:04 PM
AS always thanks Martin for your expertise and continuing support of such unique products
Chief
beojeff
USA
Posts 2,012
beojeff replied on Mon, Feb 5 2018 11:57 AM
Another solution would be to plug your existing cable as is into a barrel adapter and plug a 5-pin din cable into the other end of the barrel adapter. Those pins are easy to lose and difficult to screw back in.
Dillen
Posts 13,191
Dillen replied on Mon, Feb 5 2018 12:51 PM
It would work, but there's really no room for it under the Beomaster, where the sockets are.
beojeff
USA
Posts 2,012
beojeff replied on Mon, Feb 5 2018 7:26 PM
Dillen:
The coupler would not go where the sockets are. It's used to connect two lengths of cable together. I know from experience that trying to reinsert the pins at a later time is quite difficult and nice to avoid.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
What is the problem with screwing in the pins, it only requires a suitable screwdriver?
Regards Graham
Dillen
Posts 13,191
Dillen replied on Mon, Feb 5 2018 10:09 PM
I start the screws using just my fingertips and then finish them tight with a small screwdriver.
Never had a problem. Huh?
Page 1 of 1 (10 items) | RSS
