Best way to stream media to a BV7 1.gen
This post has 11 Replies | 2 Followers
martinmathisen
Posts 10
martinmathisen Posted: Tue, Oct 9 2012 5:27 PM
Hi Guys.
I was wondering if anyone knows of a good product to stream files from my NAS to my Beovision 7-40 1.gen.  My TV only has a DVI input, so no HDMI.
2 wishes:
1: The box should ideally run Plex or XBMC or anyhing similar
2: Using the BO remote to control the box
All the best
hfat
Vienna, Austria
Posts 663
hfat replied on Tue, Oct 9 2012 6:59 PM
If you want to run xbmc, have a look at the hw proposals at xbmc.org.
The latest version of PUC supports Microsoft 1039 remote controller (media center edition), so B&O remote can directly control the box.
hfat
martinmathisen
Posts 10
I might be stupid, but i cannot find anything about this on the xbmc.org site. Do you have a link?
The only i know of from before is Boxee, but no other output than HDMI.
Ehlerz
Posts 51
Ehlerz replied on Tue, Oct 9 2012 9:43 PM
Apple Tv 2 jailbreaked will work with plex and B&O PUC. I have this setup running on similar product (BC 6-23). Be aware that you will need a DA converter for sound.
/Ehlerz
Vienna
make an educated guess
Posts 1,090
Vienna replied on Tue, Oct 9 2012 10:02 PM
There are some xbmc based streaming clients and they should all work via B&O PUC for Microsoft 1039.
HFX Cine Play XB2 streaming client tested on recet BV10-46 and 7-40 using QNAP as well as WD NAS.
B&O PUC for Microsoft 1039 is working. Real fun if you are using a customized user interface on a Beo 6.
http://www.hfx.at/index.php?option=com_content&view=article&id=543&Itemid=210
You'll need a TOSLINK >> SPDIF COAX translator
(plus an update of the AC3 SW of your BeoVision to use PCM Audio)
martinmathisen
Posts 10
Thanks guys. I have never seen these products before. But all of them have only HDMI output, and since i have a Gen.1 7-40, i am uncertain if it will at all accept a digital signal. Is it possible to upgrade the TV?
Vienna
Posts 1,090
Vienna replied on Tue, Oct 9 2012 10:56 PM
martinmathisen:
... read the specs of the HFX box closely ...  Whistle
martinmathisen
Posts 10
yup, got it!. thanks!
need to check if my tv accepts dvi, or if it needs to be upgraded now.
thanks again
martinmathisen
Posts 10
thanks again
martinmathisen
Posts 10
thanks again
Bouncer
Posts 20
Bouncer replied on Wed, Oct 10 2012 6:52 AM
Hi there,
I also have the old type BV7.  I use Sony PS3 to connect the NAS to BV7 and it works fine.
You also need the optical to co-axial convertor for the sound or just accept the normal phono jack for the audio.
I have also connect the IR blaster to control the PS3 but you may need the firmware update to include PS3 in the PUC list.
Bouncer
Ehlerz
Posts 51
Ehlerz replied on Wed, Oct 10 2012 11:03 AM
Bouncer:
Actually, one the 1 generation BV, there is no support for stereo sound through coaxial input AFAIK. You will need to run analog audio if you also want it to work with anything else than 5.1.  You might be able to opgrade your tv a bit (HW and SW) and have it work, but i dont remember if this was also an option for 1 gen BV 7.
/Ehlerz
Page 1 of 1 (12 items) | RSS
