Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Hi! After all,it is just matter of sound.And your room acoustic will have greatest influence.Just try different placements/settings,whatever convenient to your ears...
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
You'll also find that if you ever add a second bl2 to the room, with the proper placement you'll find that the sub has a more "natural" presence in the room.
bramble:..... when the other half hears/feels the rumble of one bl2, there will not be a 2nd Like your style
Like your style
Interestingly, I don't find that 2 BL2s double the rumble. Rather, it makes them less noticeable and more natural-sounding when placed in opposite corners of the room. I don't know if there's any actual science to this. It's just my perception.
Subwoofers should come in pairs ;-))
Move it around and try all the setting but as often as not room layout and furniture dictate placement.
This reminds me to try a second BL2.
I did try BL2 as part of my music setup.
After 2 months of torture, I realized that it was inappropriate for music.
It's ok for home theater.
