I would like to by a nice multiroom speaker for my bedroom and my dealer gave me the Beosound 1 to test it at home. It is a wonderful speaker and I would like to buy it, but the is a small :-) problem with it.
When the speaker is switched off, the small Lens LED (in the middle, under the touch plate) is always on! The speaker should stand on my bedside table but the LED is to bright!
Is there a possibility to switch it out? I don't know, why this nice speaker as this standby LED. My Beosound 35 doesn't habe any LED on, when they are switched off.
Thanks for your answer.
Mirco
Sorry, no - but when in stand by the LED will dim to a faint glow. The LED is rather intense when the product is ON.
Roger
Yes, the PCB47 can be disconnected - but the LED does provide useful information, so I would consider placing a small removable "hat" on top of the LED instead so that you can sort out these situations:
White flashing slowly Starting up
White solid Connected to network, ready for use
Blue flashing fast Bluetooth pairing ongoing
Blue shortly Bluetooth connection successful
Red shortly Bluetooth connection unsuccessful
Blue solid When not configured to network and not in configuration mode
Amber flashing fast Ready for network setup. Soft AP / WAC mode
Amber flashing slowly Connecting to network
Amber solid Wireless connection of medium quality
Red solid Wireless connection of poor quality
Red flashing fast Failed to connect to wireless network
Would be nice if Bang & Olufsen simply adds a software update to change the LED behaviour, e.g. solid red in standby mode...
