When I want to change the volume by using the wheel, I face always a little lag until the volume is finally modified. It seems that the Bluetooth connection has to be established first and only then commands are accepted. I don't note that by using the left, right buttons or on and off.
Can anyone please confirm that behavior. Is it a setting issue?
Same here.
It is the same when you pair the remote with a M5, as I also did.
I don't mind, as it would be more annoying when the remote is taken to another location and you incidentically turn the wheel and the mk2 or M5 would react instantly.
