Yes new screen required. Dead easy fix yourself job!
Hi
The LCD is easy enough to replace and shouldn't cost a fortune. When we change them at Wilmslow we give the whole remote a thorough valet and they come up looking as good as new.
Opman
Try here for spares - they are very helpful: http://www.avaservices.co.uk/
Will do thanks.
Seriously,- Your Beo4 has properly served its time. Buy a new one and enjoy it for the next ten years
BEOVOX141:Seriously,- Your Beo4 has properly served its time. Buy a new one and enjoy it for the next ten years
Then its most likely NOT the display but the conductive "rubber.
Sometimes cleaning the rubber with Isopropylic alcohol can fix it, or simply removing the display an putting it back in.
In the year 2000 Ericsson almost lost its cellphone business to the unreliable "zebra strips",- you are not alone!
BEOVOX141:Then its most likely NOT the display but the conductive "rubber. Sometimes cleaning the rubber with Isopropylic alcohol can fix it, or simply removing the display an putting it back in. In the year 2000 Ericsson almost lost its cellphone business to the unreliable "zebra strips",- you are not alone!
