They are mask programmed. You cannot "reset" a dead processor.They rarely fail - but of course it can die if handled badly during service (lack of ESD-protedtion), if it experienced anovervoltage, was fitted the wrong way around or similar.Martin
Just have to be patient and wait for one to show up on Ebay. Occasionally someone is parting out a damaged unit where you can grab the microcomputer assembly. I have acquired a few that way. If I spot one I will try and remember to message you.
sonavor:Just have to be patient and wait for one to show up on Ebay. Occasionally someone is parting out a damaged unit where you can grab the microcomputer assembly. I have acquired a few that way. If I spot one I will try and remember to message you.
The Beogram 8000 and Beogram 8002 processors are not the same so yes, please save your money and wait for the correct one.
That's the right one for the Beogram 8002. Brand new in the box (NOS)? Where did you find it?
sonavor:That's the right one for the Beogram 8002. Brand new in the box (NOS)? Where did you find it?
On Beogram 800x restorations I completely strip everything down...never found any worms though. I have run across some insect remnants :-). I think I bought some of those parts from that estate sale as well. It was someone in Illinois, right?
I have never seen a microcomputer for any of these Beogram 800x turntables soldered. They always had an IC socket. I would recommend getting a good, tulip-pin style socket and install that. Martin gave me a good tip a while back regarding not installing the new IC socket all the way flush with the board. By doing that you can insure that the thermal paste will make good contact with the microcomputer IC and the metal lid of the shielding box. There are also some small resistors underneath the microcomputer IC so it would be best to use a socket for that reason too.
That’s probably the same estate. Lots of good stuff in Illinois.
The first BG8000 I bought had the processor soldered in. I desoldered it a couple pins at a time because I was so paranoid about over heating it. But that table was also someone’s failed project so it might not have started that way. I bought new pin connectors in bulk at that time so I always replace them too. I have been mounting the pin connectors as high as I could because I didn’t want to mess with the cooling contact with the housing.
This is my 6th 800x, they get so much easier each time. Your work is an inspiration!
