I've tried the bolt fix but I've found I loose the ability to find tune the tonearm. I'm posting my fix which doesn't interfere with adjustment. I'm one finger typing so i will just post images.
It's a fine line between collecting and hoarding, and I'm always dancing on it. Beomaster 8000 x2, Beocord 8004, Beomaster 6000, Beocord 9000, CDX, Beomaster 6500, Beocord 6500, Beogram 6500 CD, Beogram 6500 Turntable, BeoSound 2300, BeoSound 2000, BeoLab 8000, BeoLab 6000, BeoLab 2 Sub, BeoVox S45.2 x4, BeoVox S75, BeoVox S120, BeoVox M150, BeoVox MS150, RL140, BeoTime, BeoCom 1
Bend so that it pops through the hole
Top view
Finished product
What is it that your using? What is it called and where can I get it? At a hardware store?
This is a good solution too
use a scew with nut
wilfried
I’m going to try the bolt method today. I keep searching the forum and can’t find the thread describing the fix. Do I need to take off the carriage sled? Or should I be able to find a bolt of suitable length that I can fit into the hole from underneath the sled?
It looks like a 1/4 inch ring cotter pin. In the USA they sell them at Home Depot.
-sonavor
did you manage the screw method ? looking for some pic if you have.
[fixing same issue on my Beogram 3300]
tnx ! Ronen
