beosound 3200
jenronn
Posts 1
jenronn Posted: Wed, Apr 18 2018 3:59 AM
I have one of Cd  lights out on left side is this an easy replacement? I am generally pretty good with electronics but a bit uncertain with B&O.  Thank you for any help.
solderon29
U.K.West Midlands
Posts 764
It's a wired in lamp,so you will need to do some soldering.They rarely fail,so it may be a "dry" soldered joint though
The whole front moulding will to come off for access,so if you are a bit apprehensive about venturing in there,prap's best left to someone with experience?
The full manual is on site if you upgrade your membership(recommended anyway!)
The lamp is bound to be an odd value,but member Dillen,will almost certainly be able to help with a replacement.
Nick
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
If I remember correctly, B&O would only supply the replacement bulb/reflector assembly complete, at a horrendously expensive price.
I am sure Martin (Dillen) will have solved that particular riddle.
Regards Graham
Page 1 of 1 (3 items) | RSS
