Hue Adrress?
This post has 12 Replies | 0 Followers
chucky
Posts 331
chucky Posted: Sat, Apr 21 2018 11:01 PM
I just added 2 lights in a bedroom form Hue. Imported the scene. First Setup was done by a technician, I am simply adding lights.
Setup was Garage - Hue light x- Light dimmer - 1 (Address from 1-9)
Now adding
Childsroom - Hue light x+1-Light dimmer - 10
I did import the resource and the address it gives is 'streaming' so just changed it to the next number 10
What am I doing wrong? It simply does not work.
Thanks Chucky
chucky
Posts 331
chucky replied on Sun, Apr 22 2018 11:36 AM
This is really not OK, had to log in and push commands like debug etc... it should be simple.
Got it working though.
Chris Hassell
London
Posts 396
chucky:
Now adding
Thanks Chucky
From Beovision to doorbel...all B&O what rings.
I’ve noticed this as well. Had to manually input an ID for each dimmer or they wouldn’t respond.
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
chucky
Posts 331
chucky replied on Sun, Apr 22 2018 4:45 PM
Check these out CHRIS, hue switch from Gira, wireless and the work great.
https://www.gira.com/nl_NL/gebaeudetechnik/produkte/manuelle_lichtsteuerung/zigbee-lightlink/features.html
Batteries 2 years, a pain to program with the btidge but when they work.Cool
I use them with the BLGW. I am now looking to sen ir commands through the BV and beo 4 switching them with a light control but I am not technical
Chris Hassell
London
Posts 396
Ooooh they look cool!
Chris Hassell
London
Posts 396
chucky:
I use them with the BLGW. I am now looking to sen ir commands through the BV and beo 4 switching them with a light control but I am not technical From Beovision to doorbel...all B&O what rings.
Hey Chucky, can you pickup these commands on the BLGW directly from the switch?
chucky
Posts 331
chucky replied on Fri, May 4 2018 6:38 AM
No, the switches work stand alone, they do not have an ir or are visable in the Hue bridge. I think you can even prgram them without the hue bridge, I did put them in the bridge but when I launch an Api I do no see them.
Workaround could be to set the lights, program in the switch amd then save the scenario on the hue bridge. I did program my beo 4”s in every room and have full control and an ipad with the beolink 2 app.
Still in the in hunt to get my lutron in the living and kitchen going, bought an rs232 interface on eBay yesterday.Lets have a Party !!! got it cheap so let”s hope it works.
BeoWillie
Calgary, Alberta, Canada
Posts 15
Hey 'chucky' what Lutron platform are you using?
chucky
Posts 331
chucky replied on Fri, May 4 2018 12:08 PM
Grx|-3104
I just bought this on ebay
Lutron Grafik eye rs232 interface
Grx-CI-RS232
Chris Hassell
London
Posts 396
How do you setup the switches with the hue bulbs then?
Cheers
Chris
chucky
Posts 331
chucky replied on Sun, May 6 2018 7:02 AM
You pair them by linking the 50cm per bulb and push 2 buttons. Not really very easy but it is really set and forget. Only difference with Hue is you can use max 10 bulbs per switch, in my case not a problem as I only use them in the bedrooms. For the living I use lutron. If I had te rewire I would have used lutron as this is also not really cheap.
https://www.gira.com/nl_BE/gebaeudetechnik/produkte/manuelle_lichtsteuerung/zigbee-lightlink/features.html
When I want all lights off I have a macro in the gateway on a beo 4. Light and then 99. Works fine.
I was thinking, what happens if you push a command on the lutron switcht say in my example a 3000 series on an interface. I have nothing attached through wires just the switch and the interface, will the gateway pick up the command and can you then program a macro on the gateway sending a scene to the Hue?
TWG
Posts 1,672
TWG replied on Sun, May 6 2018 7:11 AM
THANK YOU for the hint to the GIRA Zigbee switches! Didn't know about them before. Thumbs Up
chucky
Posts 331
chucky replied on Sun, May 6 2018 2:53 PM
Your welcome, the fit in any standard Dutch or German socket plate as wel
Page 1 of 1 (13 items) | RSS
