Beocenter 2300 to Beolab 3500 speaker Aux input?
pauljrog
Posts 92
pauljrog Posted: Wed, Oct 17 2012 5:28 PM
Hi, I have a Beocenter 2300 which I have recently connected to a Beolab 3500 link speaker using a 1611 converter, it works well and sounds great.
As i'm using the Aux port from the Beocenter 2300 to the converter,using a 7 pin datalink cable, then masterlink to the Beolab 3500. How can I connect a 3.5mm aux input to play through the speaker?? as there is no other Aux input to the Beocenter or Beolab units??
Any help would be appreiciated.
Paul.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Oct 17 2012 6:10 PM
you need one of these from our sponsor at the foot of the page: http://www.soundsheavenly.co.uk/bando-auxy.htm
marrow999
Posts 1
marrow999 replied on Mon, Jun 1 2015 10:35 PM
Hi Paul
Three years later...
I am trying to achieve a similar result to you. However my converter is a 1614? I have masterlink from the 3500 into one end of the converter. The other end has two 7pin din sockets marked aux audio link and power link. Connecting either of these to the aux socket on the 2300 produces no link/sound.....
Using a beo4 the 3500 responds to the CD command with CD in the display but then vanishes. I have the a.opt on the 2300 set to 0
Any help or advice would be fabulous
Many thanks
Mark
Page 1 of 1 (3 items) | RSS
