Beovox CX100 Speaker Wire Polarity?
This post has 8 Replies | 2 Followers
SurreyNick
Posts 29
Am I being a complete numpty here?
I have always been under the impression that, when installed professionally, the speaker wire with the stripe is connected to the negative terminal of the DIN connector.  The picture here shows the 2-Pin DIN connector for a Beovox CX100 speaker and unless I’m mistaken the striped wire, which is uppermost, is attached to the positive terminal of the connector.
This is the wrong way around isn’t it?
It’s important because the previous owner removed the male DIN connector from the other end of the cable and I’m going to attach new ones.
Nick
leosgonewild
Helsinki, Finland
Posts 2,373
I have always used the striped wire, wire with text, wire with texture as positive.
As long as it goes into the correct hole in the amp it doesn’t matter, but you know that already Smile
SurreyNick
Posts 29
Perhaps I've always harboured the wrong idea.  I have just shoved a probe on it and the striped cable is connected to the positive terminal of the female DIN.
Nick
Saint Beogrowler
Saint Paul
Posts 780
SurreyNick:
Nick
This confused me when I was new to B&O since some newer speaker cables have the word POSITIVE+ on one lead and a stripe on the other.
But all my B&O cables are stripe to the pin, positive.
SurreyNick
Posts 29
Well, there we have it.  B&O have striped lead to positive.  Useful to know as I also have a lovely pair of Beovox 2702 speakers which are in need of DIN connectors and the cable for these is the single colour type with just a slightly raised edge on one lead.  I think I can now take it that this will be the positive lead.
Nick
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, May 22 2018 7:30 AM
SurreyNick:
Nick
Not as a general rule, I'm afraid.
I have seen several pairs, where the lead with the raised edge was the positive on one speaker and the negative on the other...
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Nick,
Please don't worry, there is no absolute convention here!  Most people will tend to place the wire marker (be that a stripe or text) on the positive terminal, but some factory made cables can be assembled with the marker on the negative wire.  As long as both ends of the wire are connected the same way, you won't have any issues.
It is worth noting that the smaller terminal (round pin) is positive, while the larger one (flat pin) is negative.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
SurreyNick
Posts 29
Steve at Sounds Heavenly:
Noted Yes - thumbs up
Nick
SurreyNick
Posts 29
Dillen:
Really?  Wow!  Just goes to show you shouldn't take anything for granted eh.
Better not be lazy then.  I'll pop the grills off and do a battery test
Thanks for the heads up Smile
Nick
Page 1 of 1 (9 items) | RSS
