Hi everyone just wondering if anyone knew the answer to the following :
1. The Beosound 1, how many Watts does it use under normal use? As an example, the 450 watt Naim Muso QB states 15 watts under normal usage.
2. What is the battery size in Mah (if anyone knows) of the Beosound 1 and how long does it take to fully charge?
any help is appreciated as I am planning on buying a wireless speaker for my motorhome and I am looking at the best options sound vs wattage/consumption.
