Need a new servo wheel for the tone arm on my beogram 4000
This post has 4 Replies | 2 Followers
alysvand
Posts 6
alysvand Posted: Wed, Mar 7 2012 12:21 PM
Where can I get my hands on one?
Step1
Manchester, UK
Posts 1,268
Step1 replied on Wed, Mar 7 2012 12:41 PM
I think your best bet will be to repair the current one or locate an appropriate pulley wheel. You could ask Dillen if he has any but I bet he hasn't scrapped many of these decks in his working life!
If you do repair it has to be perpendicular to the shaft otherwise noise is likely to transfer to the arm!
Olly
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Mar 7 2012 1:15 PM
I had the same problem.
I used one from a 4002, but you could also use a legotechnic or meccano wheel.
See what I did here.
Martin (aka Dillen)  once had the project of replicating those, but I'm not sure he has... ask him and tell us!
Jacques
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Mar 7 2012 4:57 PM
To complicate matters, there are at least two sizes - the mounting hole varies in diameter! Mend the old one!
Peter
alysvand
Posts 6
Oki. Thanks I´ll try to mend the one I got.
Page 1 of 1 (5 items) | RSS
