BeoGram 5005 connected to BeoCenter 9300 no sound
This post has 5 Replies | 0 Followers
David
New York USA
Posts 44
David Posted: Sat, May 26 2018 5:05 PM
I have acquired preowned beogram 5005 and connecting it to beocenter 9300 using PHONO/AUX input, however the is sound at all.
Using brand new MMC3 cartridge.
From what I understand 9300 has built in pre-amp.
Seems like BeoGram issue - could it be that I'm doing something wrong?
Thanks,
David
BeoSystem 3
BeoSound 9000
BeoLab 8000/6000/4000/3500/BL2
PlayMaker
BeoCenter 9300
BeoGram 5500
BeoCom1/1600 + BeoTalk 1200
BeoCord vx5500
MediaBobNY
Greenwich Village, NYC
Posts 1,106
No, there is no RIAA preamp in a BC 9300.   You'll need a standalone - try www.phonopreamps.com
Peter
Earsdon
Posts 11,991
Peter replied on Sun, May 27 2018 7:07 PM
You should get some sound - just thin and quiet. You need an RIAA but it should still be able to heard.
Peter
David
New York USA
Posts 44
David replied on Mon, May 28 2018 1:23 PM
I do indeed hear very thin sound.
Thank you! I should start looking for Beogram 9500 or 4500. Is there a significant different between two?
BeoSystem 3
BeoSound 9000
PlayMaker
BeoCenter 9300
BeoGram 5500
BeoCord vx5500
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
The Beogram 9500 does not have built in RIAA.
You should look for a Beogram 3500, 4500, 6500 or 7000 or an older Beogram 6000 Quad. However, these will all be expensive as they are much rarer than the non RIAA models, especially when in good condition.
The Phonopreamps.com TC770 LC model is ideal if you decide to buy a stand alone RIAA pre amp as it is high gain to compensate for the low output of B&O cartridges.
https://www.phonopreamps.com/TC-770LCpp.html
Regards Graham
David
New York USA
Posts 44
David replied on Mon, May 28 2018 3:34 PM
Thank you!
BeoSystem 3
BeoSound 9000
PlayMaker
BeoCenter 9300
BeoGram 5500
BeoCord vx5500
Page 1 of 1 (6 items) | RSS
