beosound 1 - cd player not working. How much to fix?
This post has 6 Replies | 2 Followers
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Sat, Nov 3 2012 4:56 PM
Does anyone know the cost of fixing the cd player in the Beosound 1 - the cd spins but the laser is not working.
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Nov 3 2012 5:56 PM
jinkster:
Thanks.
you could try a cleaning cd first, sometimes this works.
best regards
Ralf
Chris Harrison
Peak District
Posts 381
I will have a go at that one. I spoke to B&O and they quoted around £200 - £300 to fix the CD player. Are there any specialists out there to save going to dealers?
Thanks.
Mindphaser
Posts 100
Chris Harrison:
Thanks.
Well;
the amount requested seems outrageous to me; changing laser on an Ouverture (which is way harder to disassemble than a Beosound 1) will cost less  !
Anyway, you can ask AV Repair if they can change the laser for a lower amount...damn, 200-300 £ is incredible, you'll buy another Beosound 1 instead of repairing your actual one !
Chris Harrison
Peak District
Posts 381
Is it possible to connect a beolab 3500 to a beosound 1 - somehow or other!
carlito
Posts 239
carlito replied on Tue, Nov 6 2012 3:53 PM
Defenitive no chance!
Cheapest way to build up a Masterlink Network is buying a used Beosound Ouverture - or an Beomaster4500 / 6500 / 7000, Beocenter 2300 with using a Masterlink-Converter
Mindphaser
Posts 100
Chris Harrison:
BL3500 is Masterlink only AFAIK;  moreover, on Page 5 of the Userguide it's written:
"Note: Although BeoLab 3500 has a Power Link socket, it can not be used as an ordinary Power Link loudspeaker in a audio or video system! "
So, no way !
Page 1 of 1 (7 items) | RSS
