How long?
This post has 65 Replies | 2 Followers
Sandyb
Posts 2,186
Sandyb replied on Sun, Jun 17 2018 8:07 PM
Compared to the C7 - Bluetooth connectivity.
On the C7, not on the Eclipse.
Millemissen
Flensborg, Denmark
Posts 14,680
Yes, but you were talking about an Eclipse....not a LG C7 ;-)
Sandyb
Posts 2,186
Sandyb replied on Sun, Jun 17 2018 10:41 PM
Not sure why this is so difficult to understand.
The Eclipse is a C7 with B&O sound. Yet in so doing they disabled one of the potentially very useful features of the C7.
As others owners have stated, i'd be livid with that outcome.
But of course B&O can do no wrong......
Millemissen
Flensborg, Denmark
Posts 14,680
Sandyb:
That is exactly my point: the Eclipse is NOT an LG C7 with B&O sound!
It is an C7, which (for the sound part) was modified for working with the Sound Center, that B&O has built.
Yes, of course B&O can do something ‘wrong’ - but in this case it is simply a matter of choosing to let ALL audio processing be made from their own device (= the Sound Center).
The did not promise you any bluetooth out connection - why should you be disappointed then?
Sandyb
Posts 2,186
Sandyb replied on Sun, Jun 17 2018 11:16 PM
I have high standards.
You can choose to extend as much generosity and courtesy as you want. That's your choice of course.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Jun 18 2018 6:20 AM
Sandyb:
this contradicts in the evolving discussion with MM! If you have high standards, you should/would know on forehand the specification of the Eclipse and the specs of the LG C7. And they are not 100% exactly the same. So why criticize the Eclipse for lacking specs of the LG C7?
Sandyb:
thus MM hasn't high standards, so his opinion is lesser than yours? So you are right?
Sandyb
Posts 2,186
Sandyb replied on Mon, Jun 18 2018 7:09 AM
No contradiction - i was merely making the point initially that the Eclipse is a bit of frankenstein mix, which to some extent it clearly is.
And i used the example of the loss of the BT headphone connectivity from the underlying panel as a strange side effect - one which others have mentioned, and one that would have annoyed me. Of course i dont own an Eclipse, and its hypothetical, and generally i do my research beforehand.
But the broader point remains - a C7 owner can use his BT headphones, an Eclipse owner cannot. Given the genesis of the Eclipse, that's a slightly weird, and difficult to reconcile outcome. Whether that's important to you or not, is of course down to the individual.
My sister just bought a 700 GBP Sony Bravia - it has BT headphone connectivity.
But go right ahead, and defend B&O from removing it / not offering it on an 8k set.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Jun 18 2018 7:25 AM
Sandyb:
Where do you read I'm defending it?
I solemnly make a note about the arguments made and the call to "supremacy".
Millemissen
Flensborg, Denmark
Posts 14,680
Neither do I ‘defend’ it - I merely underlined that B&O has choosen to do all audio processing on their own (and thanks for that).
As a result there is is no support for the BT-out as in the native LG C7 tv.
Wheher they could have built-in BT support in their own audio solution, I have no idea.
Some may miss it - others won’t.
Sandyb
Posts 2,186
Sandyb replied on Mon, Jun 18 2018 10:20 AM
You dont need to point out what B&O have done capability wise - we're all well aware of that, i can read a spec sheet.
Of course losing the BT audio option will matter less to some, more to others.
I used it as an example of the size effects of the  hybrid / modular / frankestein approach that has produced this BV.
Adding the BT capability is hardly complex, and either seems an overnight, a strange deliberate choice, or somehow necessitated by the hybrid approach.
Either way, not optimal, especially considering its not a complex functionality they've left out.
My initial point was that under this approach, these side effects need to be better managed by B&O.
Pointing out that its not in the end products spec doesn't address the central point.
There are other examples of compromise that exist in the Eclipse - again, sensitivity amongst the customer base will vary, but they are there.
My hope, as expressed initially, was that any future BV's manage these compromises better.
Emil Jensen
Denmark
Posts 766
But being disappointed about a feature missing that have never been advertised seems…
And Eclipse have a ton of features that the C7 do not have.
Anyways about product without software failure seems impossible in 2018 sadly,
But I enjoy my Eclipse everyday without any issues, and just looking forward to My buttons is added, seems weird that it is taking so long, but personally I did know this before buying so I have a bit of patience left.
Sandyb
Posts 2,186
Sandyb replied on Mon, Jun 18 2018 3:09 PM
indeed, its not the most important feature.
i use it more as an example of one of the odd compromises that can happen with the hybrid approach.
Especially when it is featured on many lower priced TV's.
Seeing and selecting sources on the remote, as opposed to also on the on screen menus, to me is another. Again, not crucial, but again a bit strange to me.
My hope for the future was that this partnership approach would produce fewer such compromises in any future BV's.
Not an unreasonable wish.
As for software stability, that's another thing.
Emil Jensen
Denmark
Posts 766
Sorry, this one I do not understand?
Do you mean you would also be able to choose input in the TV menu?
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Jun 18 2018 6:01 PM
Wow, this thread has gone somewhat off-topic.
One thing is clear, no-one on here, even those guys are a little more 'in the know' than others, have any clear idea of what's coming? Most dealers have a reasonable idea what's in the pipeline, even if they haven't seen products in the flesh. I remember my local dealer used to get preview emails from B&O months before a launch (he couldn't share the info, but he'd drop hints).
Correct me if I'm wrong, but we knew the BeoLab 50 was coming quite a while before it's August 2017 launch? We definitely all knew the Eclipse was coming at least 4-6 months prior to launch!
Now, nothing?
Sandyb
Posts 2,186
Sandyb replied on Mon, Jun 18 2018 6:07 PM
Apologies, my fault somewhat.
davidr
Montréal
Posts 172
davidr replied on Mon, Jun 18 2018 6:32 PM
Millemissen:
Actually I think B&O has the right idea. I have slightly older LG OLED and it's bluetooth is useless. For whatever reason LG had originally only allowed their own LG soundbars to pair. Indeed on my set I can't pair any BT audio device to it - curious to try.
Unless LG has changed their mind recently regarding third-party BT devices, B&O probably just had them disable it.
Besides, BT audio in general is terrible and unreliable.
Sandyb
Posts 2,186
Sandyb replied on Mon, Jun 18 2018 6:47 PM
Reading avforums.com, there are LG owners who are using other BT headphones with their LG TV, without any transmitter.
Anyway, BT audio is not the end of the world - was just using it an example of one of the odd compromises inherent in the Eclipse.
I was playing with an Eclipse recently - didnt realise that the source selection was visible only on the remote, and not also on the main LG UI / menu.
Unless the store was misinforming me, that's just another example of what appears to me a less coherent product than i'd expect for the price.
They do better next time, they have my money.
Aussie Michael
Melbourne, AU
Posts 3,730
Sandyb:
I understood you.
I thought that the next product was the BL3 replacement. That is love to hear and see.
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Jun 18 2018 7:16 PM
Sandyb:
Cool. Ok, back on topic? Can you all take the Eclipse discussion to the Eclipse thread?
Sandyb
Posts 2,186
Sandyb replied on Mon, Jun 18 2018 7:32 PM
done, my bad
Sandyb
Posts 2,186
Sandyb replied on Mon, Jun 18 2018 7:35 PM
Wireless BL3 - done.
Who do i pay?
Aussie Michael
Melbourne, AU
Posts 3,730
Sandyb:
Who do i pay?
Same.
I was thinking of BL17 but I’m waiting for BL3 WISA
poodleboy
Posts 303
poodleboy replied on Mon, Jun 18 2018 9:18 PM
Aussie Michael:
Sandyb:
Who do i pay?
Same.
After essentially replacing the 4000 with the 17 with its stamped aluminum front and plastic back, I don't think I want to see what B&O/Sparkle would do to the BL3.
Millemissen
Flensborg, Denmark
Posts 14,680
Aussie Michael:
Sandyb:
Who do i pay?
Same.
Actually I am expecting a bit more than ‘just’ a WiSA-BL3.
That would be too easy ;-)
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Jun 20 2018 10:14 AM
Millemissen:
And almost certainly would have been out by now - it would have just replaced the existing BL3.
I love my BL3s. Probably the best performance versus size and cost.
I wonder how many people walk in to a B&O store in 2018 simply to look at speakers? And what do most people connect them to, B&O system aside?
Aussie Michael
Melbourne, AU
Posts 3,730
moxxey:
Well they were connecting the 90s to an Oppo Player.
Page 2 of 2 (66 items) < Previous 1 2 | RSS
