Functions on BR1
chucky
Posts 331
chucky Posted: Thu, Jul 12 2018 4:52 PM
I close a skylight using on-off1 on a beo4 through control menu
The same is on the BR1 Which is set up in Beo4 mode
It should be function_21 however on the BR1 BT nothing....
Which command should I use?
Thanks Chucky
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jul 12 2018 5:04 PM
The BLGW is very useful for monitoring which commands are sent when pressing those BeoRemote One Light/Control buttons. I made a list of many of them (not with me at the moment thought). However, I discovered that when you add some buttons to the list, then more LIGHT/CONTROL buttons can often become available to add as well. Sometimes you don't see these buttons as available to add until you make another button available on the list.
BTW, on the BLGW macros, you can have multiple triggers. Therefore, you don't have to get rid of the Beo4 command that you're accustomed to using. The Beo4 can use a different command than the BeoRemote One.
chucky
Posts 331
chucky replied on Thu, Jul 12 2018 7:12 PM
Dag Jeff
You”re right I can monitor through the BLGW, Not the easiest to read sometimes but it will work,
Thx Chucky
beojeff
USA
Posts 2,012
beojeff replied on Fri, Jul 13 2018 12:21 AM
Here is a (perhaps partial) list of the BeoRemote One LIGHT/CONTROL commands that I monitored through BLGW:
LIGHT FUNCTION 1 = MORNING
LIGHT FUNCTION 2 = LEAVING
LIGHT FIUNCTION 3 =  COMING HOME
LIGHT FUNTION 4 = TV VIEWING
LIGHT FUNCTION 5 = EVENING
LIGHT FUNCTION 6 =  MUSIC
LIGHT FUNCTION 7 = RELAX
LIGHT FUNCTION 8 = SLEEP
LIGHT FUNCTION 9 = GENERAL
LIGHT FUNCTION 10 = OUTDOOR
LIGHT FUNCTION 11 = HOME
LIGHT FUNCTION 12 = DINNER
LIGHT FUNCTION 13 = CINEMA
LIGHT FUNCITON 14 = BEDTIME
LIGHT FUNCTION 15 = NIGHT
LIGHT FUNCTION 16 = WELCOME HOME
LIGHT FUNCTION 17 = GOODBYE
CONTROL FUNCTION 1 =  WINDOW 1
CONTROL FUNCTION 2 = WINDOW 2
CONTROL FUNCTION 3 – WINDOW 3
CONTROL FUNCTION 4 = WINDOW 4
CONTROL FUNCTION 5 =  WINDOW 5
CONTROL FUNCTION 11 = CURTAIN 1
CONTROL FUNCTION 12 =  CURTAIN 2
CONTROL FUNCTION 13 = CURTAIN 3
CONTROL FUNTION 14 = CURTAIN 4
CONTROL FUNCTION 15 = CURTAIN 5
CONTROL FUNCTION 21 =  ON_OFF1
 CONTROL FUNCTION 22 = ON_OFF2
CONTROL FUNCTION 23 =  ON_OFF3
CONTROL FUNCTION 24 = ON_OFF4
CONTROL FUNCTION 25 = ON_OFF5
CONTROL FUNCTION 16 = SHADE 1
CONTROL FUNCTION 17 = SHADE 2
CONTROL FUNCTION  18 = SHADE 3
CONTROL FUNCTION 19= SHADE 4
CONTROL FUNCTION 20 = SHADE 5
CONTROL FUNCTION 21 = FAN
CONTROL FUNCTION 22 = DOORLOCK
CONTROL FUNCTION 23 = ALARM
chucky
Posts 331
chucky replied on Sat, Jul 14 2018 12:44 AM
Thanks Jeff Fan works!
beojeff
USA
Posts 2,012
beojeff replied on Mon, Jul 16 2018 6:35 PM
I'm glad it helped.
If anyone has additions to make to my list, please do. It could be a useful resource to have around.
Page 1 of 1 (6 items) | RSS
