Beolab 5 problem
politician
Posts 180
politician Posted: Mon, Nov 5 2012 3:33 PM
Hello! I'm hoping somebody might be able to help me diagnose and remedy a fault with one of my Lab 5s. Since Saturday night, the left-hand speaker has been produced an annoying high-pitched whistle (almost like a bicycle that needs oiling) whenever it's switched on. The sound is coming from the calibration microphone in the base rather than the speaker itself. Attempts to recalibrate have produced a series of awful grinding noises rather than the usual sounds, and the sequence never completes. Unplugging and replugging the speaker has made no difference whatsoever. Does anyone have any idea what is going on?
Seanie_230
UK
Posts 2,278
Maybe a different username would help get a response..... Just kidding
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
maclife
Brussels, Belgium
Posts 18
maclife replied on Tue, Nov 6 2012 12:10 PM
politician:
Does the microphone come out for measuring the usual way? If not, it might be a mechanical problem.
politician
Posts 180
Yes, the microphone extends normally when I attempt to recalibrate, so it is not a mechanical issue. Could it be some kind of software fault? Also, is it possible to switch off the microphone in some way? That would resolve the problem instantly, as the speaker is playing perfectly normally.
BeoSeeker
Posts 6
Silver Member
I have seen this a few times when the supply voltage drops below threshold on the Microphone unit. Its a relatively inexpensive fix, but takes a bit of time to replace it. Heres the part number if interested 8470042. As far as disabling the calibration mic, not an option as the micro in the chassis will continue to look for calibration results. Hope this helps.
politician
Posts 180
Fantastic. Thanks!
Page 1 of 1 (6 items) | RSS
