Beosound 9000 MK1 & PC/MP3 Playback?
This post has 9 Replies | 1 Follower
Beonic
Posts 21
Beonic Posted: Fri, Nov 9 2012 3:00 PM
I have just aquired a Beosound 9000 MK1 (1997 model - Type No: 2521, Serial No: 1215****)
Connecting possibilities: Powerlink, Masterlink, Digital out and Antenna.
I was wondering if anyone has succesfully been able to play from any soundsource other than CD and Radio from this system an if so how they did it and what converters they used?
Any answers will be much appreciated.
elephant
AU
Posts 8,219
Beonic:
Isn't there an AUX-IN ?
BeoNut since '75
Beobuddy
Utrecht, The Netherlands
Posts 3,972
For the 252x versions (mkI and mkII) is there softwareupdate 2.2. available.
This software update makes the BS9000 Netmusic/Netradio compatible.
Beonic
Posts 21
Beonic replied on Fri, Nov 9 2012 9:47 PM
Ok, what does that mean exactly?
Is all MK1 BS9000 252x version, if not how do I check this?
and how do I update the software in this?
olvisab
Posts 1,391
olvisab replied on Fri, Nov 9 2012 10:09 PM
Hi
You don't seem to know where the label is located.
You will find it under  the keyboard of the beosound.
BR
OLivier
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, Nov 9 2012 11:11 PM
There is an Aux socket next to the two Powerlink loudspeaker sockets. The Aux socket is a 7 pin din socket but you can use a standard 5 pin plug to connect to an external device. A popular option is to get a 5 pin din plug to 3.5mm jack plug. This allows you to play audio from any device with a headphone socket. Alternatively you can use 5 pin din plug to two phono plugs and connect to a device with line level output.
Opman
elephant
AU
Posts 8,219
elephant replied on Sat, Nov 10 2012 12:14 AM
Opman:
And that will let you attach a Playmaker or an Apple Airport Express so that you can play digital music collections - including from a network storage device or your portable devices (phone, tablet)
Or, if you have a digital music collection on a PC (Apple or Windows) you can attach a BeoPort black box and play N-Music from the PC's digital library or internet radio's (N-Radio)
BeoNut since '75
Vienna
make an educated guess
Posts 1,090
Vienna replied on Sat, Nov 10 2012 12:29 AM
Opman:
if you want to connect a device with a "3,5mm earphone socket" order from your B&O dealer (for approx 15 EUR)
a "Cable 7pin DIN < > JACK 3.5mm / 3m"  - B&O Item# 6277956
Beonic
Posts 21
Beonic replied on Sat, Nov 10 2012 1:07 AM
Thanks for the answers!
So I only need "7DIN to 3.5mm Jack" plug then, I do not need to get any software updates?
Vienna
Posts 1,090
Vienna replied on Sat, Nov 10 2012 1:22 AM
Beonic:
You'll need the SW update (exchaging an EPROM chip) only if you aditionally want to use a
BeoMaster5+BeoSound 5 or BeoLink PC2 = BeoPort in the the MasterLink setup TOGETHER
with your BeoSound 9000.
 Then you can control all sources from every link-room via your Beo 4/5/6 remote.
The simple "cable solution" does of course not offer any control of the "external" source.
Page 1 of 1 (10 items) | RSS
