Option 5 and rear speaker ?
Silou
Switzerland
Posts 465
Silou Posted: Thu, Jul 26 2018 12:03 PM
According to the schematic I would like :
  • Listen the audio with the lower speaker or listen the audio with the upper ones. It must be ok with option 5 or 6 (I?m not sure wich one)
But… but…
Is it possible to use the upper soeakers as rear speaker for the BV ?
Thanks for your advices!
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 26 2018 12:10 PM
Which manual and page are you referring to ?
BeoNut since '75
RaMaBo
near Munich
Posts 626
RaMaBo replied on Thu, Jul 26 2018 1:26 PM
no you can't listen to Surround sound with your linked speakers.
The reason is that the multichannel processing is done in the TV and the signals are routed to the powerlink connectors at the TV. The multichannel source signal is _not_ transferred via masterlink, which is only stereo capable.
Option 4 should be the best if available. (2 receivers in one room, 1st main, 2nd in L-shaped room, as B&O always says, even if it's not L-Shaped Smile
@elephant: there's a small attachment, a PDF which shows what he plans to do Smile
Ralph-Marcus
Page 1 of 1 (3 items) | RSS
