Beoplay S8 rattle from sub.
This post has 6 Replies | 0 Followers
jacobtc
Posts 9
jacobtc Posted: Sun, Jul 29 2018 4:53 PM
I went out a bought a used pair of S8's including the Connection hub. I didn't have the opportunity to take a listen at sellers house, so I transported them home safely to set them up. At some frequencies the sub makes a rattling noise, sounds like a mix of a loose screw and electrical noise, however it might just be the rubber surround which is worn? What do you think? And can I fix it? The warranty ran out in March...
Take a listen. https://www.youtube.com/watch?v=EMVROLMCAKA
Saint Beogrowler
Saint Paul
Posts 780
That video doesn’t help at all. Maybe play some more music for a longer period of time so we can hear what is happening. I’ve owned a couple of S8s. Pretty fun speaker. Can you reproduce the noises without the satellites attached?
Did a child drop a penny in the top port?
jacobtc
Posts 9
jacobtc replied on Sun, Jul 29 2018 6:04 PM
Its the rattle heard more prominently in the end of the video. I will try to see if I can reproduce it with music playing instead. I haven't tried with the satellites attached, but I'm certain that the sound comes from the sub.
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Jul 29 2018 6:43 PM
Does anything rattle if you shake the sub?
BeoMegaMan
Posts 601
That noise is usually the internal bass tube which has broken off its mount internally. A common problem that happened in shipping usually. If you can open it up you should be able to glue/epoxy it back.
Ah, you know... A little B&O here, a little there
jacobtc
Posts 9
jacobtc replied on Sun, Jul 29 2018 9:16 PM
Hiort:
No, nothing rattles when shaking it.
jacobtc
Posts 9
jacobtc replied on Sun, Jul 29 2018 9:17 PM
BeoMegaMan:
How hard is it usually to glue back on?
Page 1 of 1 (7 items) | RSS
