Midrange speaker RL140
This post has 9 Replies | 0 Followers
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie Posted: Tue, Nov 13 2012 9:12 PM
It seems that one of my RL140 has a failure. The midrange speaker does not work.
How can I test if the speaker is okay or could it be one of the components on the crossover board?Embarrassed
If the speaker is defect does anyone have such a type (ITT). Martin?
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Swap them to one where the driver work, check the Ohms on the driver coil, if working in the other speaker, check the crossover: caps, resistors, and soldering.
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Nov 13 2012 10:01 PM
Thanks Soren! In case the speaker is kaputt is there a replacement or do they existy in other speakers like RL60's?
Brengen & Ophalen
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Nov 13 2012 10:19 PM
Yes.
But try what Søren suggests first.
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Nov 13 2012 10:32 PM
Will do, thanks Martin!
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Nov 16 2012 5:57 AM
No need, got another pair of RL140'sBig Smile
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Leslie:
Leslie, you have to save the other pairLaughing
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Nov 16 2012 4:28 PM
Søren Mexico:
Leslie:
Well my friend, at least you can laugh after your last message!Whistle
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Leslie:
All done and forgotten, we look forward to new adventures with B&O, and you are still here, which shows that you are a real Beoworlder.Yes - thumbs up
Leslie
Posts 5,423
Silver Member
Leslie replied on Fri, Nov 16 2012 9:50 PM
That's the real spirit Soren! I know if you appear to much on Beoworld showing your stuff and (hard) work over and over again it can be annoying for some Whistle but what do I care. B&O is my passion..... But.. I must admit, you're comment made me think (a little bit)!
Brengen & Ophalen
Page 1 of 1 (10 items) | RSS
