Hello, everyone. I was directed to join here but a member of audiokarma, upon posting this question over there. I have a B&O TX2 that turned out to have a dead bulb in the tonearm optical sensor assembly. I have taken it apart, and am now looking for an appropriate replacement. I would imagine that light output is fairly important, in order for the light sensor to send the correct voltage to the motor control. I know that the original bulb is 14v and 50ma, but I am having trouble finding an exact replacement. There is a pack of 100 on ebay that have those same specifications, but A) i don't have any use for the other 99 and B) trusting, what I assume is, Chinese parts is less than ideal.
Anyway, if anyone could point me in the right direction, I would greatly appreciate it.
Thanks!
Martin will have them I am sure
https://beoparts.com/
