BeoTime chime not working
This post has 7 Replies | 2 Followers
frog
Camberley UK
Posts 624
frog Posted: Fri, Aug 31 2018 12:28 PM
hi,
i have a beotime and the chime  isn’t working for the alarm. I’ve changed the batteries, but while it can control switching something on, the chime doesn’t start up. Oddly, one in a while when I press the flute back in, I get one chime, so I know the chime itself is working.
‘’Any thoughts on how to switch the chime back on?
leosgonewild
Helsinki, Finland
Posts 2,373
It has a bad contact. You need to disassemble the entire unit. And the part is very difficult to remove.
Get the service manual.
Good luck Big Smile
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi frog,
My Beotime also has this problem - I didn't want to risk opening it up so I have lived with the fault for a year or so, now I prefer it this way (The Beotime activates my bedroom lights and music from my Beosystem 3500 in the lounge below, so it is much more restful to wake up to gentle music and the light gradually brightening without the incessant chiming!)
Sorry if that wasn't the answer you wanted......
Kind regards, Steve.
Steve.
www.soundsheavenly.com
leosgonewild
Helsinki, Finland
Posts 2,373
Steve, do you remember they key-sequence to activate the hidden functions?
frog
Camberley UK
Posts 624
frog replied on Fri, Aug 31 2018 1:49 PM
Yes, I have opened one before - and it wasn’t pretty. I think I’ll live with it as it is!
Posts 2,165
Hi Leo,
No problem!  Here is a link to my earlier Beoworld post with all the details: https://archivedforum2.beoworld.org/forums/p/1771/15052.aspx
Steve.
leosgonewild
Helsinki, Finland
Posts 2,373
I was asking so Frog would get the info Stick out tongue
My days with the Beotime is over Wink
Page 1 of 1 (8 items) | RSS
