Beovision 7-32 MK1
honest_paul
Posts 8
honest_paul Posted: Sun, Sep 9 2018 8:27 PM
HI I have been gifted a 9314 with Beolab 7.1 and a wall mount for it, its missing a mains power cord so I was wondering if the plugs fuse should be 3 or 5 or 13 amp ?
Also missing the 2 screws to attach the bracket on to the TV, and missing one screw to attach the Beolab to the speaker bracket, many thanks for reading and any reply.
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Sep 10 2018 9:14 AM
Typical power consumptions for the TV and speaker are 152 and 20 watts respectively, so you should be fine with a 3 amp fuse.
I think that the screws attaching the TV to the bracket are M5 x 20mm, but am not sure!  Don't know about the speaker screws either.
honest_paul
Posts 8
many thanks for your reply, i shall go with the 3amp cheersYes - thumbs up
Page 1 of 1 (3 items) | RSS
