Beovision 8 26/32 Hdmi vs VGA
This post has 10 Replies | 1 Follower
Master123456789
Posts 237
Master123456789 Posted: Mon, Sep 10 2018 4:28 PM
Hello forum
I have two tv-boxes a DVB-T and a DVB-S as I want to use on a Beovision 8 26/32. So I was thinking of using the HDMI and the VGA (via HDMI to VGA cable with sound).
Are there any of you who have tried the two ports - are there any difference on the picture quality?
There are a big difference on HDMI and scart, though it is not a HD television.
Millemissen
Flensborg, Denmark
Posts 14,680
How about using a switch for the HDMI-in?
Master123456789
Posts 237
would rather like to use to channels at the tv, like v.mem and dvd.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Although you can input 720p signals to the Beovision 8 26/32 via VGA and Component video, the clarity via HDMI is FAR BETTER.  I use HDMI for my Humax Freesat box (used 95% of the time) to my BV8-32, with VGA for the PC input (3% usage) and Component Video for the PS3 (2%).
An HDMI switch box is another option to connect more than one box via HDMI, but the TV will only be able to control one device this way (I would suggest setting the STB output to control the device that you use the most).
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Millemissen
Flensborg, Denmark
Posts 14,680
Another solution would be to get a combi-box with both S and T tuners.
Master123456789
Posts 237
Okay, if the VGA has a bader picture, then I must use a HDMI splitter.
A combi-box that can handle Canal Digital Denmark and the new german DVB-signal (H.265) is hard to find.
Millemissen
Flensborg, Denmark
Posts 14,680
Master123456789:
Ja, det er helt sikkert ikke muligt!
Master123456789
Posts 237
Det er en CD entertain mini boks - ved du om det er muligt at udskifte DVB-T modulet til et nyt opdateret med H.265?
Sorry we write in danish! ;-)
Millemissen
Flensborg, Denmark
Posts 14,680
Master123456789:
Det kan jeg bestemt ikke forestille mig - H.265 som kodning af DVB-T bruges så vidt jeg ved kun i Tyskland.
Hvilke (tyske) DVB-T programmer er det, du vil ha fat i?
Måske ville en ATV4-boks med CD’s app plus de fra nogle af de tyske kanaler også være en mulighed.
Så er der kun brug for én HDMI.
Master123456789
Posts 237
Tænkte at det måske kunne være muligt selv at finde reservedelen, som er selve DVB-T tuneren. Nej det er ingenlunde muligt at gøre det fra Canal Digitals side. Så skulle man selv kunne åbne boksen op og sætte et andet DVB-T modul i.
Jeg kører hellere to bokse med en hdmi-splitter end alt muligt med Apple tv. Jeg vil gerne se alle de tyske public service, Das Erste, ZDF, dritte programme, Arte, 3sat, Phoenix osv.
Tror det ender med en Hdmi-splitter - også begrænset hvad man vil ofte på et BV 8-26-32 ;-)
Master123456789
Posts 237
I now have tried a computer with HDMI and VGA - when I have set the screen solution right at VGA - NO difference at the picture between HDMI and VGA.
Page 1 of 1 (11 items) | RSS
