BeoRemote 1 and NOT having radio as default 1st music source?
kmspurway
Posts 23
kmspurway Posted: Fri, Oct 12 2018 2:02 PM
hello all
I have a BeoRemote 1 Infra Red remote in beo4 mode for a link room - to control a ml beolab 3500. Works well enough but there doesn't seem to be any way to NOT have RADIO as the first / default music source chosen and displayed.
This means that I always have to then select CD or A.MEM on the remote after the radio is started on the main system......
My dealer couldn't seem to even remove Radio as a source - even when unticking it as a source on the remote or re-order the sources so that CD was first one shown
Any ideas / solutions gratefully received
thanks
L Spad
Brighton
Posts 271
L Spad replied on Fri, Oct 12 2018 2:17 PM
Hi there,
You should be able to change that behaviour through the "list" menu as follows:
List > Settings > Advanced > Buttons > Music
Select "None" and you should get the behaviour you want. Alternatively you could choose another source to start on the Music button press. Same applies for video.
Removing the Radio source is really easy too:
List > Settings > Music Sources > Show
Just choose radio and the tick next to the source name will disappear - done!
L Spad
Brighton
Posts 271
L Spad replied on Sun, Oct 14 2018 11:49 AM
Hi there,
I tried to post an answer on Friday, but it seems to have been lost in the ether!
In order to change the default behaviour of the Music key you need to go to
Select the "None" option. Alternatively you could select a different source to play automatically when you hit the Music Key
To remove the Radio option from the source list you should navigate to
Scroll down to Radio and hit select. The little tick will disappear from next to the Radio source and it will no longer show up in the source list under Music.
Hope that helps
Luke
Page 1 of 1 (3 items) | RSS
