Beoplay h9i "thump sound".
This post has 7 Replies | 0 Followers
keniutek
Poland
Posts 1
keniutek Posted: Mon, Oct 15 2018 11:29 AM
Hello.
I noticed that my pair of h9i's distorts when walking (bluetooth, anc on). When i walk at a faster pace and my foot hits the ground, there's this distortion/sound in the earcups (left one being more audible). With anc off it's much better but you can still hear it from time to time. Anyone here having same problems or found a solution?
TIA, regards
jans
Belgium
Posts 394
jans replied on Mon, Oct 15 2018 12:20 PM
My son mentioned a similar problem. He reported it to B&O but didn’t get a satisfactory answer
w5bno123
London
Posts 578
w5bno123 replied on Mon, Oct 15 2018 1:03 PM
keniutek:
Hello.
TIA, regards
I have found the degree of thump depends on what type of shoe you wear. If you’re wearing a trainer with soft heels it’s not noticeable compared to smart work shoes. Your movement is amplified through your bone structure up to your ears which have been isolated by very powerful ANC headphones. This isn’t a technical fault.
bonerp
Posts 4
bonerp replied on Sat, Mar 30 2019 2:58 PM
It is poor design though. My sennheiser pxc550 nor beats wireless did this. I've just bought a pair of h9i and can't get over this. Happens on left more so than right. Trying the H7 pads....
bonerp
Posts 4
bonerp replied on Mon, Apr 1 2019 11:25 AM
UPDATE:  The H7 ear pads remove the 'thump' created by ANC :)
And they are soooo much more comfortable.  Why B&O ever changed these for the thin standard ones I'll never know.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Mon, Apr 1 2019 12:51 PM
Well, I do hope that you also provide this feedback directly to B&O to ensure that the next generation H9 gets on-track and better.
Michael
Sweden
Posts 2,578
Michael replied on Mon, Apr 1 2019 1:05 PM
bonerp:
Can you show a picture of the difference? I also have the thump noise when walking with ANC and thought it was due to the in ear cup microphone and the air pressure change when walking and the headphones compresses a bit due to gravity and momentum.
bonerp
Posts 4
bonerp replied on Tue, Jun 4 2019 7:49 AM
I'm afraid that this doesn't fix it.  You can't walk heavily in shoes - better in trainers.  I'm going to report it.  Not good enough for such a high end model.
Page 1 of 1 (8 items) | RSS
