Beogram 5500
Chris
Australia
Posts 26
Silver Member
Chris Posted: Sat, Oct 20 2018 9:01 AM
Hi.  I have a coupIe of questions.
1  I want to do some work on my turntable's lid that has quite a few scratches.  What's the best way to remove the lid?  Try and undo screws on hinges or undo the back of turntable and go from there?
2  I've seen that some B & O turntables can be put into a service position.  Is that possible with this turntable?
Thanks for the advice.
Chris
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Oct 20 2018 10:38 AM
1. Go in from the back and unscrew the hinges from the deck.
2. Yes. It's in the servicemanual. But it won't provide better access for lid service.
Chris
Australia
Posts 26
Silver Member
Chris replied on Sat, Oct 20 2018 11:14 AM
Thanks Martin. Always good advice.  Smile
Anders Jørgensen
Denmark
Posts 350
Depends on where the scratches are I recently got try Novus on my Beogram 6500. The top of the clear part was quite scratched but the treatment 1,2 and 3 did the magic. Now I can see clearly through the top of the lid
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 20 2018 11:21 PM
I did one, but you never can get the same level of transparency as when it was new: there is always a very slight haze to it. But you can eliminate the light scratches with a little Brasso and car polish, with some elbow grease too of course!
Jacques
Page 1 of 1 (5 items) | RSS
