The magic B&O APP screenshot for ML/NL?
This post has 18 Replies | 1 Follower
danielshen
Posts 78
danielshen Posted: Tue, Oct 30 2018 2:25 AM
Dear all,
I have the beosound 9000 as main room and Beolink active connecting beolab 3 as link room; I want to add the NL/ML converter to make the whole enviornment NetworkLink ready;
But I really want to see the screenshot of B&O APP with the beosound 9000 and Beolink active (beolab3) or similar old products (maybe beosound 3000) in the APP - I think this is very magic! I trust we can almost control everything to the beosound 9000 and the beolink active.Can anybody share such screenshot for me?
After I have such impression, I think I will buy the NL/ML converter. Thanks!
Daniel
elephant
AU
Posts 8,219
elephant replied on Tue, Oct 30 2018 4:30 AM
I’ll post my setup in action for you:
+ Core — BL20s
NL
+ Essence — BL11 — BL6000s
+ BLC
NL/ML
+ BV8 — BL19 & BL3s &BL4s (5.1)
+ BSound4 (no speakers)
BeoNut since '75
danielshen
Posts 78
This is BO app I mentioned:
danielshen
Posts 78
This is BO APP i mentioned:
danielshen
Posts 78
Hi elephant,
I am waiting your screenshot of BO APP configuration. And one more thing: to add the old product like beosound9000, we do that in the NL/ML web config page or BO App?
elephant
AU
Posts 8,219
elephant replied on Tue, Oct 30 2018 5:57 AM
danielshen:
Hi elephant,
You will need the NL/ML configuration app which is complicated !
When you press on the product it invokes an appropriate configuration software program.
As I am not at home I can only show the surface of the App and not the underlying details.
BeoNut since '75
Soren
Denmark
Posts 115
Soren replied on Tue, Oct 30 2018 6:21 AM
Hi Daniel
You won’t be able to see a picture of your BS9000 within  the Bang & Olufsen app... you can give it any name you want, but the picture will always be of the “ugly” converter you can see on elephants screenshots
That means that you can’t see all your Masterlink products and control them separately within the app... In many way you can look at the converter as an “link room” products that can play the sources from your mainroom Masterlink system and  all the NL sources in your house
Furthermore you can also link the NL products into your Masterlink system
Søren
Sendt fra min iPad
danielshen
Posts 78
Soren,
In your view, then my beosound 9000 and old beolink active - baolab 3 in total will be viewed as one single item: The converter. I think that is your suggestion, right?
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Oct 30 2018 7:37 AM
danielshen:
Soren,
That is correct. Only the picture of the NL/ML converter will be shown in the app.
That is the way it works.
Millemissen
Flensborg, Denmark
Posts 14,680
Hiort:
At least untill the app-makers maybe at some point decide for the possibility of placing your own/other pictures there.
Aussie Michael
Melbourne, AU
Posts 3,730
Hiort:
I wonder if that changes. For example when I connected the essence. I didn’t call it essence I called it beolab 3. I wonder if it works the same way.
Aussie Michael
Melbourne, AU
Posts 3,730
... as in the name and not the picture.
elephant
AU
Posts 8,219
elephant replied on Tue, Oct 30 2018 10:30 AM
Soren:
However if you buy a separate converter for each piece of ML kit you get greater granularity.
In my case I bought one and defined it as an audio-visual system so I could (partially) control the BeoSound 4 and control the BeoVision 8.
Others on BeoWorld have bought two Converters and I believe in one case three !!!
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Tue, Oct 30 2018 10:39 AM
I am back home so some more screen shots including an answer for Michael H/Aussie ...
So here we try to drill into the BLC BL/ml but don’t get far, then by contrast we drill into the Essence (called 6000 because of its BeoLabs) we get to the start of its configuration screens.
And that’s as far as you can go !
Now the driver of the 6000s ...
Which does invoke the configuration software for the Essence (or the Core)
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Tue, Oct 30 2018 10:45 AM
And here is how you have to use the old out of date depreciated app to get to configure your BLC BL/ml
Which makes me wonder if you can even download the App if you have not already got a copy !
Tomorrow (if I can find the password) I’ll show the next level of screens.......
BeoNut since '75
Soren
Denmark
Posts 115
Soren replied on Tue, Oct 30 2018 2:36 PM
Millemissen:
Hiort:
It would be really nice if they added the possibility to add your own pictures in the app, but that won’t change the fact that you still only see one item.
It is correct that if you add multiple converters you would have access to more Masterlink products, but it’s still only the Audio and Video masters, It’s not possible to turn on Link room products like BL2000/3500 and Beolink active on with the app.
Some of the older products also don’t have fully functionality........ on my Beosystem 7000 I can turn it on and off and change source and channel, but it is not possible to adjust the volume with the app, I don’t know if it is possible on BS9000.. it probably is due to the Masterlink connector.
Søren
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Oct 30 2018 7:10 PM
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Oct 30 2018 7:11 PM
elephant
AU
Posts 8,219
Thanks @Carolpa !
Those screen shots were very interesting.
Do you have a wiring / room / kit diagram to share ?
BeoNut since '75
Page 1 of 1 (19 items) | RSS
