Does anyone have the last configtool for me?I have tried several website links but they did not workplease could anyone help me out?
www.mediafire.com/download/6s2l3qs88zqz9x1/CTSetup_6.84.exe
Link not working😢
It's working for me! Thank you BeoFrank.
I have now downloaded it with google crome, and it works..
Thanks 👍😀
Anyone know the username and password for it?
Jeff
I wonder if now that the Beo6 has been discontinued if B&O might be more agreeable to BeoWorld offering the software on this site.
Jeff: Anyone know the username and password for it?
Hi Jeff,
the user and password is only necessary if you want to up- or download a configuration to the B&O server. It's not needed
The configs will then be stored on your local harddsik. Just hit 'Cancel'
Ralph-Marcus
Hi RaMaBo,
To me (VMware on OSX) I can't skip the step. If I hit cancel the Config Tool Quit. If i check "work offline" and click "OK", nothing happens.
Thanks RaMaBo, I tried that after I posted but wasn't sure it would work properly in that mode. Once I ever get the battery fixed in my Beo5 I should be good to go.
Its works on a 32bit Windows machine.
