Hi Guys, I got a nice Beogram 1700 table as part of a Beomaster 1900 and S45-2 purchase. The Beogram 1700 has a broken dust cover but otherwise is supposed to work. It has a MMC10E cartridge; not sure if that is good/bad?. It is broken where most of them seem to break: the tonearm side plastic hinging.
I am not really a phono type guy, but I would love to get this guy back to working.
I have the ability to get a broken Beogram RX cheap, which appears to have the same dust cover. This RX table looks like the 1700 with the four buttons on the left-hand side, rather than the RX on this Beoworld site product listing which has the three buttons on the tonearm side.
Does anyone know if the dust covers are interchangeable?
The Beogram 1700 dustcover appears to be 17 inch X 12 inches 5/16
thanks
Does anyone know if the dust covers are interchangeable between the Beogram RX and the Beogram 1700?
The Beogram 1700 dustcover appears to be 17 inch X 12 5/16 inches. If anyone has a Beogram RX does your measurements match mine? I am assuming the hinges are the same?
dup
