Hej Hoppas på lite hjälp.
Har bytt Bv-10 till BV-11 har nya IR-ögon från Beovision 10 kan man klippa jacket och monterar RJ45?i IR-öget ? det en svart och en svartvit ledning , hvordan skal de in i RJ 45 kontakten. Eller må man köpa nytt till Beovision 11
Hej berit,
Sorry for replying in English.
You can connect this adapter onto the existing 3.5mm IR cable to use it with the Beovision 11, but this will only give you one output for each RJ45 plug (PUC-B):-
https://soundsheavenly.com/televisions/178-2548-35mm-to-rj45-ir-puc-adapter-for-beoplay-v1-beovision-1112avanteclipse.html#/9-length-18m
The other option is to install a new RJ45 IR cable, this way you will get two outputs from each RJ45 plug:-
https://soundsheavenly.com/televisions/60-2545-ir-transmitter-blaster-for-beosystem-4-beoplay-v1-and-beovision-11avant-rj45-control-socket.html#/2-length-1m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Det nemmeste ville være at hente/få sendt en lille adapter til formålet.
Bare sig:
6271233
IR-blaster Adaptor, Mini Jack 3.5 mm, Mono, Female to RJ45 (PUC A) 0.2 m / 0.7 ft
til din forhandler
Hvis du selv vil og kan lave det, kan dette måske hjælpe:
