Dear members,
is it possible to connect the Beosound 4 to an old two-way AV9000? Both do use Masterlink, but slightly different versions of it, I guess?
Greetings,
Kai
Just to give the answer since I have now tested this:
The Beosound 4 (and probably also any other masterlink product) does fully integrate with the old two-way AV9000. You even get the same (at least to the extent that I was able to test) two-way functionality as when connecting the MPAV9000, which I find to be quite amazing.
Greetings, Kai
