My 23 years old Beomaster 4500 does not play anymore. It starts with remote or touch, the realys are clicking but no sound of any source and this happens 1 day before x-mas:-(
Any ideas from here? All connectors are fine and the active speaker lights are green...
Merry x-mas
Thomas
Did you check the headphone socket?
Stefan
Muting-relay?Does the speaker set 2 sockets work?
Merry X-mas everyone!
Yes Stefan - headphones are working - does that mean that the mute relay has gone?
Regards
Hi Martin,
your guess muting relay is quite possible as headphones are working...
kadl18: Merry X-mas everyone! Yes Stefan - headphones are working - does that mean that the mute relay has gone? Regards Thomas
I think Stefan also meant you to check that you have not left a 3.5mm headphone adaptor in the headphone socket - this would mute the speakers. This has happened many times in the past, so you wouldn't be the first!
Merry Christmas, also!
Hi everyone,
at the end i found out, that it wasn´t the Beomaster but both Beolab 8000 are gone. Any suggestions about typical issues one these?
