How to connect BeoLab 8000 to BeoVision 8?
aryak
Posts 6
aryak Posted: Wed, Jan 2 2019 8:49 AM
Hi all,
I apologize in advance if I'm not an expert or won't use professional terms, however I have the power and din cables for beolab 8000 but literally as I tried to connect them to the beovision 8 I noticed the tv only has one outlet and not two... which means it only seems to support one speaker at the time
Any ideas what am I missing? owners manual didn't help much
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi aryak,
You can connect two speakers to the single Powerlink socket on the TV by using two Powerlink cables and a Powerlink splitter:-
Splitter: https://soundsheavenly.com/bang-olufsen/26-129-powerlink-compatible-splitter-doubler-2-fully-wired-powerlink-compatible-sockets.html#/20-length-02m
Cables (x2): https://soundsheavenly.com/powerlink-8-pin-din-connection/20-266-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/1-length-05m
Please ask if you need any further help.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
