Is this wattage math right?
This post has 6 Replies | 0 Followers
dilznik
Posts 29
dilznik Posted: Fri, Nov 23 2012 5:41 AM
Hi there,
I just moved from Australia to the US with my B&O gear and I want to hook some of it up in my temporary apartment.
I have a BS4, a pair of BL6000, and a Beolink PC2 or whatever it's called.  As far as I can tell that's a total of 53.2 watts.  Here's what I found:
bs4: 12w
BL6000: 38watts (pair)
Beolink PC2: 3.2 watts
Can someone tell me if I'm looking at the right thing before I buy a 110 to 220 convertor?  Thanks.
dilznik
Posts 29
dilznik replied on Fri, Nov 23 2012 5:46 AM
Hmmmm I just found this: http://www.beoworld.org/prod_list.asp
IT says my math should be more like this:
bs4: 25w
BL6000: 120watts (pair)
So I guess I'll get a 750 watt convertor and never have any problems. Big Smile
Søren Mexico
Mexico City
Posts 6,411
dilznik:
bs4: 25w
Even a 500 W would do, but with a 750 W your can connect another pair of speakers or whatever with 200 W
dilznik
Posts 29
dilznik replied on Fri, Nov 23 2012 5:12 PM
They're pretty cheap and small these days so I'm thinking that's the way to go.
Cheers.
Søren Mexico
Mexico City
Posts 6,411
dilznik:
Cheers.
Got a Chinese one for my work, 500 W and has been working for a year without problems, but gets hot when going to the limit, so go for your 750 W and you should be OK.
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Nov 23 2012 7:59 PM
Søren Mexico:
Yes, it's generally a good idea to dimension stuff like this so that it won't be running on its last legs so to speak. All you'll lose is a bit of wasted standby power and the transformer itself will be a bit bulkier of course.
But, are you ever planning to move back and still keep all the kit with you? If not, it might be worthwhile to have the Beolabs converted to 120V. It's not a big job, and the rest of the units would happily run on a very small step-down step-up transformer.
--mika
Søren Mexico
Mexico City
Posts 6,411
Forgot to mention, if you have 2 or 3 phases incoming to your house, you can pull 220/60Hz, from 2 phases, I have installed a couple of 220V outlets in my house, works like a charm. But be careful and mark the outlets loud and clear 220V
Page 1 of 1 (7 items) | RSS
