I have today upgraded from a Mac Mini based roon installation to a roon Nucleus.
The roon Nucleus is via USB connected to the BeoLab 50.
This works excellent.
I can even now control the volume of the BL50 internal DAC via the roon UI.
roon Nucleus => USB => BL50 works very well.
- Flere
smile and enjoy the moment
That's interesting. Did you get the plus model? Do you use it for Tidal, or ripped FLAC's etc?
:)D
so i tried setting up a roon server (using a mac mini) and connect them to the USB-in on my BL90's. Sound was great, but the main issue that I just could not find a way around was that it reset volume to max every time I started it up. Max on the BL90 is really really loud...
I tried all kinda settings to change this, but no luck...
The BL90 App allows you to set default volume for all imputes. Default for powerlink is IIRC 48. However, Oppo SPdif works at the same leve at 40
Mr 10Percent: Hi, The BL90 App allows you to set default volume for all imputes. Default for powerlink is IIRC 48. However, Oppo SPdif works at the same leve at 40
yep - but it seems that via USB the volume is controlled by the player rather than BL90
Ditlev:yep - but it seems that via USB the volume is controlled by the player rather than BL90
Ditlev:That's interesting. Did you get the plus model? Do you use it for Tidal, or ripped FLAC's etc? :) D
hi Flere, is your lab 50 still connected to a B&O tv also?
and if you connect the Roon Nucleus to the usb port of the master Lab 50, how does that work to activate the speakers ?is that automaticity done by starting Roon on a tablet ?seems that it's impossible to connect the Nucleus directly to the Eclipse tv
thanksJan
jandrego: hi Flere, is your lab 50 still connected to a B&O tv also? and if you connect the Roon Nucleus to the usb port of the master Lab 50, how does that work to activate the speakers ?is that automaticity done by starting Roon on a tablet ?seems that it's impossible to connect the Nucleus directly to the Eclipse tv thanksJan
Hi Jan,
No, my BL50 master is only connected via USB to the ROON Nucleus.
I do not have a TV anymore, already for 1.5 years.
I control the ROON Nucleus via the ROON Mac app on my Apple iMac or via the iOS ROON app on iPad or iPhone.
When I start the music on the ROON the BL50s are activated and start playing the music.
When the ROON stops playing music then after 10 seconds the BL50s will go to sleep again.
Volume control is via volume control on the ROON.
Works very well. And of course super sound.
HAGWE
Flere: Volume control is via volume control on the ROON.
What I mean is that the volume is controlled via the ROON apps.
And in my configuration the ROON Nucleus tells the BL50 via the USB connection what to do with the volume.
So the digital signal goes from the Nucleus to the ROON without volume interference.
So the BL50 is actually doing the volume computation.
Thanks Flere !!I am trying to find a way tu use the Nucleus , but with the 50's also connected to the Eclipse
Jan
You can use PowerLink cable connection between Eclipse and BL50 master.
And USB for the Nucleus.
Switching will be automatic and according to the priority you configure in the BL50 with the B&O app.
Flere, what kind (brand/type) of USB cable have you used?Apparently that is very important to get the best result.
Connected the Beolab 50's to a Nucleus with an audio USB cable, works perfect !!The Eclipse is also still connected with the 50's.Sound is amazing , very happy !!
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
