Hi
Hope someone can help me, I have resently moved to a new adress, and is a happy owner of an old Beosound 3000 there worked perfectly before I moved.
Now the red light in the display is just flashing without any reaction from pressing the on bottom.
And there is no pin code request!!!!
Have tried the solution twice with disconneting of power over 30 minuts and in 7 hours.
And there is still no requestig for me to type in the pincode.
Is there someone there know how to get it working again!
With best regards
Hanne
haner: Now the red light in the display is just flashing without any reaction from pressing the on bottom. And there is no pin code request!!!!
Welcome to the forum.
Even if the BeoSound is not "explicitly asking" for the PIN - just try to enter the appropriate 4-digit PIN (using the keyboard or the remote) and see what happens ...
Hay, if connected to ML you could try removing the ML cable and then try and activate CD.
i remember I had this problem years ago and the option code had changed when I removed it from the mains
Eclipse 65V1-32Beosound M5Essence MK2BLI
Thank you so much it did work out fine.
Which fix worked? I have a non responsive BS3000.
