Hi All,
I just became the new owner of a Beogram 3000 (the newer style one) and hooked it up to my Beocenter 9500, but no datalink. I checked out the forums and I found out that I am missing the data link pins for the DIN connector on my Beogram. I am wondering if anyone knows were a guy can source a new set of the threaded pins? I understand I just need one of the two to make things work?
Thanks!
hi, I have just 2 pins left for the DIN plug!
Where do you live?
Write me a PM or email, I can then send by mail for reimbursement of postage costs!
best regards
wilfried
Hello!
I am so sorry, I completely missed your reply. Do you still have the pins? I am happy to send you a thank you gift for postage (and a coffee).
PM sent...
Correct, you only need one datalink pin.
Hello Bryan, the pins are on the way!
Screwing in is a bit difficult, so this post might be helpful.
https://archivedforum2.beoworld.org/forums/p/28314/223173.aspx#223173
Btw you an and Martin are right, only pin 7 just scew in for thr datalink connention
