Beovision Motor Stand 7-32 for Beovision 10-40
nick_muc
Posts 7
nick_muc Posted: Sat, Feb 23 2019 2:56 PM
So, as I didn’t find a stand for my 10-40, I used the motor stand from my 7-32 which I had swapped already for the table mount. With the BV 10-40 back plate, everything works wonderfully apart from the motor stand which has a DIN plug, the BV10 has an 8 pin Microfit.
And here’s my question:
who knows if it’s possible to change the DIN to a Microfit and where would I get the wiring diagram?
Thanks in advance.
Nick
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Nick,
Please update your email address to a valid address as your email's are being rejected. Your email address currently has b-f.com as the domain
Regards Keith....
Jack
Poland
Posts 30
Stand, 8 pin Micro-fit
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Dec 11 2021 10:55 AM
Only just found this thread and I thought I would add a few notes as I have been experimenting with using BV7-32 stands for my BV10-32.
Firstly, an expensive solution to the OP's question could be to purchase one of these: https://shop.oneremote.dk/shop/69053-oneremote/4172-tv-stand-converter-snut/
When I purchased my BV10-32 I originally used a 10-32 motorised table stand (on the floor), but wanted to mount the TV a little higher.  I experimented with BV7-32 floor stands but these were too high (plus had the incorrect connection), so I then combined the base of the BV10 table stand with the pole from a BV7-32 table stand - I just fed the base's cable/plug up through the pole.  This worked fine, but I had to modify the BV7 stand's attachment bracket to prevent the TV from tilting backwards too far.
I have now found a proper BV10-32 motorised floor stand, hence the TV is now at the 'correct' height.
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
