I just bought Beoplay A1 and thought it would be an easy task to sync it with my beoplay M5. Afterwards I’ve found out that it may not be possible. Can someone help me out?
That will not be possible if you mean sync to play the same source, A1 is a bluetooth speaker and has no access to wifi. Therefore it cannot e.g share sources from M5.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:That will not be possible if you mean sync to play the same source, A1 is a bluetooth speaker and has no access to wifi. Therefore it cannot e.g share sources from M5.
