Hi all,
Is it possible to connect a Beoplay A9 to my Beomaster 7000. Using the powerlink output from the BM 7000 and the line in on the Beoplay A9? What powerlink cable should i use here?
Is there a better way to link these 2?
Office: Beomaster 3000-2 with Beovox P45 (all in white)
Living room: Beomaster 7000 and Beogram 7000 with Beovox RL 7000 (all in white)
Kitchen: Beocenter 2300 with Beovox 4500 (not available in white :-(
Hi Beold,
Basically, there are two options:-
1) Use this cable with the Powerlink output of the 7000 if you want to have volume control from the 7000:-
https://soundsheavenly.com/bang-olufsen/110-329-5-pin-din-to-twin-rca-powerlink-compatible-to-non-bo-hifi-amplifier-receiver-etc-din-to-twin-phono.html#/2-length-1m
2) Use the same cable in the Tape 1 or Tape 2 socket of the 7000 for volume control from the A9 - IMPORTANT NOTE: Please ask for the cable to be modified as a "TAPE OUTPUT CABLE" if choosing this option to ensure that it is wired correctly for your needs!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
